PWP 6.0.9 download Problem
dhrothstein
When I try to tun the download of PWP 6.0.9 x64 I get a message thta says c:program files is not available and the installation stops. I do not understand what is happening. I am currently running 6.0.8 with no problems.
Re: PWP 6.0.9 download Problem
dhrothstein wrote:When I try to tun the download of PWP 6.0.9 x64 I get a message thta says c:program files is not available and the installation stops. I do not understand what is happening. I am currently running 6.0.8 with no problems.
When I try to intstall 6.0.9 Pro, MS 64 bit, I get an error message about a duplicate file. That ends the install process.
MikeG
Windows 7, Home Premium, 64 bit.
Tried once. Failed.
Rebooted, tried again, same failure with the following dialog box displayed.
Tried once. Failed.
- PWP609 installation-1.JPG (40.84 KiB) Viewed 4640 times
There seems to be an installer problem. Our initial test machine did not show this problem, however another machine does. I have reinstated PWP 6.0.8 until the problem is solved. We will make an announcement when 6.0.9 becomes available.
