Stale preview window during resize processing
During resizing, there is an empty 'preview' window that disappears after the image is processed. In PWP4 such window doesn't appear.
- What is the make/model of your primary camera?: Canon R5
Re: Stale preview window during resize processing
Maciej,
I do not see an empty preview window -- does it depend on what operation you select for resizing? I use "Bounding Rectangle" most often.
Bob Walker
Bob Walker
Bob,
It doesn't depend on the mode. There is no preview window when you adjust the controls in Resize dialog, but when you hit OK and the resize is substantial (i.e. takes time to process), an empty Preview window appears during the processing, and then closes.
In 5.0 Resize has been changed from 4.0. It now uses common transformation code, to allow it to be stored in History and be made part of workflow files. This code creates the final window from the preview window, which is why you are seeing the preview window.
