AppCrash runnng workflow with Bilateral Sharpen
rpm
What is the make/model of your primary camera?: Nikon D40
Post by rpm »
Kiril,
The attached workflow contains a Bilateral Sharpen and Output transform that causes an AppCrash in the 64-bit version of PWP6.
Details:
1. Open workflow window.
2. Load workflow.
3. Load more than 4 tif files with a size of 37mb each.
4. Click GO
5. The first 4 images process successfully (OK w/Checkmarks) and then the system generates AppCrash messages. The number of AppCrash dialogs appears to depend on how many images failed to process.
Workarounds:
1. Place a breakpoint on the Bilateral Sharpen transform and all images process successfully.
2. Turn off multi-tasking in the workflow window and all images process successfully.
The system is running Windows 7/64 bit with 8GB of memory on a quad core processor.
PWP6conv_BiShrpnFinal_Output_NoBrk.zip
(498 Bytes) Downloaded 2341 times
