Batch processing problem - odd behavior with two "Batch progress" windows in view
I was performing batch processing, and abandoned changes along a breakpoint.
Upon resuming, two Batch processing progress windows could be seen.
When I terminated batch processing in one of the two Batch processing progress windows, Batch processing resumed and I was unable to Terminate batch again. Note that the check box to disable breakpoints was not checked. Despite two breakpoints, the batch processing continued until I terminated the PWP process.
Capture d’écran 2026-01-17 194042 v1.jpg (100.82 KiB) Viewed 9767 times
2026-01-17 Picture Window Pro session state and crash recovery.zip
(7.47 KiB) Downloaded 293 times
Re: Batch processing problem - odd behavior with two "Batch progress" windows in view
I was unable to reproduce the double batch progress window behavior, but I did fix a problem with canceling after changing settings at a breakpoint.
