Update Available - Version 8.0.528
An update is available to Version 8.0.528 (6-Sep-2025)
Raw Develop: fixed problems with Trim setting and with creating lens profiles in locales that do not use period as the decimal point. I recommend deleting the following two folders before installing the Picture Window update:
C:\Users\<user name>\AppData\Local\Picture Window Pro\Lens Profiles
C:\Users\<user name>\AppData\Local\Picture Window Pro\LensFun
This will cause the files in the Lens Profiles folder to be rebuilt as needed based on the latest lens database. To get the latest lens database, make sure you do a full install and not just update the executable file.
