Suggestions for batch extracting and processing multiple images
Use Case
User works with a collection of photos representing full-page layouts—such as scanned publications or photographs of photo album pages. Each page contains multiple embedded images.
Workflow involves:
  • Applying global transformations to the entire page (e.g., rotation, color correction, perspective adjustment).
  • Automatically or manually extracting each embedded image from the layout.
  • Applying a custom set of transformations to each extracted image individually.
Note: Extracted images may originate from cropping or geometric warp transformations.
Desired Capabilities
  • Automatic Sub-Image Detection as a Transformation Node
    Introduce a new transformation type: "Detect Embedded Images", which identifies and isolates individual images within a page layout.
    This transformation would iterate over all detected sub-images, treating each as a separate unit for downstream processing.
  • User-Guided Iteration and Control in the Transformation Tree
    Enable manual intervention at a designated breakpoint in the transformation tree:
    • User can manually crop or warp to define a sub-image.
    • After writing the processed image to file, provide a "Loop" or "Go Back" node that lets the user:
      • Continue extracting and processing additional sub-images from the same page.
      • Or proceed to the next page in the batch.
    This allows flexible, semi-automated workflows combining automatic detection with manual refinement.
