Problem : Breakpoint ignored
The breakpoint on transformation "2 Warp" is ignored.
Capture d’écran 2025-06-05 205112 v1.jpg (140.21 KiB) Viewed 4703 times
Crash recovery and session state are attached as zip file
P2025-06-05 Picture Window Pro Warp breakpoint not effective.zip
(4.07 KiB) Downloaded 70 times
Re: Problem : Breakpoint ignored
I edited your workspace file so the File Open file list had only 1 file instead of 17 and then substituted one of my own test files so I could get it to load. When I ran the batch it stopped on each of the three breakpoints.
Next time I will lake a movie clip !
It started misbehaving after I abandoned a change on one of the breakpoints. After that the warp breakpoint was skipped on two successive files. I then terminated the batch.
I quit PWP, and restarted the processing by opening the last successful script. Everything worked fine then.
If you were using a keyboard shortcut to cancel, is it possible you held the key down too long and it started to auto-repeat?
I don't remember exactly. I doubt it was auto repeat.
I might have hit a key by inadvertance, then possibly tried to close (x) or pressed escape.
After the glitch, the warp transformation was skipped in each one of the succeeding input files in the list.
