Write File in Export
tonygamble
Post by tonygamble »
[quoteIf Save to is set to File, there is a Write File button you can click to test your export settings by exporting the current input image. The output image is a copy of the image that will be exported[/quote]
Am I right in thinking this does not happen now?
Re: Write File in Export
There are two ways to get to the Export dialog box:
1) File/Export from the main menu -- this has no Write File button since clicking OK exports the file.
2) Transformation/Batch/Export -- opening an Export transformation -- this has a Write File button so you can test it without running a batch process.
tonygamble
Option 1 does nothing for me.
I press OK and the panel simply disappears and nothing is written into my chosen folder.
Looks like I introduced a bug while fixing something else. Will correct the problem shortly.
