Picture Window Pro 5.0.1.10 Posted
Posted: February 20th, 2011, 1:46 pm
Picture Window Pro 5.0.1.10 is now available for download.
PWP 5.0.1.10 updates the raw converter to support recently introduced cameras. Support for Samsung (.srw) raw files has been added.
The count colors function (recently discussed on the message board) now supports 48 bit images and has also been made faster than before. The function is now fairly fast as long as actual memory is available. It is much much slower if it runs out of physical memory and must use virtual memory. Please note that 48 bits introduces many more color possibilities and so Count Colors is much more likely to run out of memory before the entire image is processed. If it does run out of memory, it issues an error message but still reports the number of colors counted up until the error.
You can download the new version from http://dl-c.com/content/view/23/54/
•Website
•Website
