Roll-pitch-yaw orientation ?
netaamit
Post by netaamit »
Hi, I shot two pix of a large cathedral and stitched them using Microsoft's ICE. I was given the option to manually control the orientation, and I chose pitch -10 degrees to overcome the slight slope backwards of the cathedral. Is there a way to do so in PWP? Thanks.
Re: Roll-pitch-yaw orientation ?
Picture Window does not have the same controls as image stitching programs but it can perform perspective correction to make buildings look like they are not tilted backward. Try using the Geometry/Warp transformation -- there are examples in the Transformations.pdf file of how to use it.
