I'm looking at page 8 of the document that shows 4 images - original, LCE only,
Sharpening only, and both.
I'm puzzled that the slider all show the same settings. Should the bottom left image show the
'Pass 2' tab???
John P
multi-pass sharpening doc error?
Re: multi-pass sharpening doc error?
The enable/disable tool bar is independent of the tabs at the bottom of the dialog box. The tool bar just adds or removes a pass from the processing pipeline and thus updates the preview, and ultimately the output image if you click the red Run button or OK. The tabs simply switch which group of sliders is displayed so you can adjust each pass's settings separately -- switching tabs therefore does not affect the preview or the output image.
I was just trying to illustrate the function of the tool bar for which the tab setting does not matter, however I take your point and have changed the examples to illustrate both sets of settings and added some addition text to hopefully clarify how it works.
Jonathon -
Thanks! I figured that is how it works, I just thought having the sliders reflect the LCE vs Sharpen
setting might be a little clearer on the settings used.
PWP is a great product!
John P
John P
