Update Available - Version 8.0.3
An update is available to Version 8.0.3 (20-Oct-2019)
Color Curves: fixed problem with histogram display when RGB/All is selected.
Added updates to help file section about integration with other applications, especially Raw Therapee.
Fixed minor issues with the dialog box that lets you select a new file or switch drive letters if a file is missing when a script is run.
Autorange: fixed problem causing incorrect setting of dynamic range slider on startup in some rare cases.
Fixed typo in version check file on server causing spurious message about needing an update when using the Help/Check for Update command.
Minor fix to 8.0.3 uploaded
I found a problem with 8.0.3 just after I uploaded it and replaced it with a new copy with the same version number.
This fixes an issue with an out of date copy the version file on the server possibly being accessed from the cache instead of getting the latest version number. This only affects the Help/Check for Update command.
If you already downloaded 8.0.3, you don't need to download the whole thing again -- just download the zip file and update the core application.
