Expanded Multi Color Balance dialog...
Ref: PWP8 Beta 10-Sep-2019; Win10 Home 64-bit
1) Open an image
2) Open the Multi Color Balance transform and add a mid-tone neutral gray control point
3) Drag a transform dialog corner to enlarge the dailog
Note:
1) mouse clicking the R, G, and B channel tabs no longer have defined target areas
2) R, G, and B channel control points are not mouse accessible for click/drag when a specific channel is 'active'.
Enlarged MultiClrBal Dialog.jpg (52.12 KiB) Viewed 3815 times
Re: Expanded Multi Color Balance dialog...
PS: I was attempting to use the expanded dialog for more accuracy to adjust the channel control points somewhat similarly to what one would do with the RGB Color Curves transform... ...however the Multi Color Balance control points are curve adjustable/tab selectable at default dialog size and can be very accurately adjusted by numerical input to the Add Color 2 dialog for a specific control point.
Fixed for next release
