Bug fix release 29-Aug-2019
I have posted a new release (29-Aug-2019).
Clone: fixed redundant warning about image size change.
Clone: Fixed problem with 22-Aug version causing first stroke to be lost and number of strokes to be off by one. Cloning scripts that saved using the 22-Aug version may need to be corrected and re-saved.
File Save: removed redundant overwrite warning, and fixed problems of not setting initial file type to match original file and not being able to change the file type on a Save As.
File Save: added warning if saving a file and the original file is missing (probably renamed or deleted) as this prevents saving metadata by copying from the original file. Also fixed missing metadata when a file is written over the original copy.
File Open: fixed problems with File Open Multiple when selecting a single file. Also fixed problems with single step batch button.
Image Info: fixed problem with Command control obscuring the tabs in some cases.
Mask: fixed problem with Undo followed by change of mask mode followed by Apply not registering the mode change.
Mask: fixed a problem that was causing intermittent crash when applying a series of complex polygons or splines.
