Bug fix release 2-Aug-2019
I have posted a new release (2-Aug-2019).
Again fixed problems stopping PWP from running on systems before Windows 10 version 1703. Unfortunately, I do not have any computers running WIndows 7 or 8 here to test against, but this should work OK.
Re: Bug fix release 2-Aug-2019
I just tried the new version.
Still the same error message.
Are you sure it's exactly the same error message and that you are running the 2-Aug version? It looks like I forgot the update the version date on the 2-Aug version -- will fix this right now.
The error messages shows up as soon as I try to start the programm.
I found a computer here with Windows 8.1 and I will continue on this until I get a new version that works.
ok, no need to for a quick hack.
Good software need time.
I have a runnign program with version 2019-07-20
OK, this time I have gotten a version of 2-Aug-2019 that tests OK on Windows 8.1 and which presumably also works on Windows 7. I have replaced the 2-Aug version uploaded earlier with the update, so it will also list 2-Aug-2019 as the version.
This version seems to work now ok.
Thanks for this
Hmmm, is it just me? I installed Aug-2 updated version, and "quick pick" is no longer functioning, space bar or letter key combinations. Is that something I could have turned off by mistake?
No, it was me. Fixed for next release.
