I have posted a new release (16-Feb-2019) in full installer and executable-only versions. Minor changes to help file.
Fixed problem with Ask checkboxes in the Default File Save Options dialog box.
Export: fixed several problems.
File Save: fixed problems with wrong profile possibly being saved with files in some cases.
Bug fix release 16-Feb-2019
Re: Bug fix release 16-Feb-2019
A first short feedback:
- metadata handlings seemes ok to me
- even the situation is handled if the icc-profile is changed during workflow
- I was able to define the *.script files as buddy-files in Imatch. So the handling of these files should be easy.
- *.script files can be run from file explorer (or from Imatch, since I added a definition to Imatch for *.script files)
migrated to Windows 10 in Nov. 2019
CUDA not available
CUDA not available
Thanks for the feedback.
Hopefully this will solve the metadata problem more or less permanently. I may replace ExifTool with Exiv2 at some point as it would be faster.
