PWP Support section may not be the best place to post this suggestion, but I'm not sure where else to put it before I forget it.
I wonder if it's possible at all and if others would have a need for it:
Would it be possible to have a text comment feature, either a single one for the entire workflow (or for each widget, but I suspect it's more confusing and difficult to implement). I often use workflows which require change of settings in widget depending on the situation; sometimes figuring them out cost hours, but the conclusions can be easily forgotten unless I write them down somewhere. Saving comments with the workflow would make it much easier. Another use of comments would be preparing workflows for other users and using comments as 'Help' in running the workflow.
Comments for Workflows and/or widgets
Re: Comments for Workflows and/or widgets
Gerat idea, Maciej!
I would find it very useful to place comments with Widgets.
- What is the make/model of your primary camera?: Nokia N8-00
Another vote for a comments feature in workflow files.
