Could others check it out:
- Drag 3 images to the workflow window
- Sort manually - the sorting window appears, with 3 images in one row, and an empty space for the next image to the right
- move the middle image to the RHS end; move the middle image to the RHS end again
In my case it either crashes the sorting window or PWP.
Manual Sort in Workflow Window
Re: Manual Sort in Workflow Window
Hi Maciej,
I tried your routine, and found that, while I did not get a 'crash', clicking the OK button resulted in nothing. The OK button is hreyed out, but the 'Sort Images' window does not close. I'm still able to manually sort the images, and re-click the OK button, but again, nothing happens.
I tried this with only two images, with the same results. After repeated sorting (about 5 or 6 tries), the window closed and the new sort pattern is applied in the Workflow window. Clicking Cancel or trying to close the window with the control "X" has no effect.
With four images, everything works as it is expected right from the start.
Hope this makes sense.
Mark
Mark
There seems to be a bug in cases where there are fewer than four images. I will get a fix out for the next upgrade.
Sorry for the inconvenience.
