Crop split window missing scrollbars
Crop Split preview Side by Side:
When left input half is zoomed in, or 1:1, it does not get the scrollbars. Instead, they appear in the right output half even when the crop fits into the window and they are not necessary there.
When the cropping rectangle is small and falls outside the zoomed area, it cannot be found and repositioned since there is no Hand available either.
When the cropping rectangle falls inside the zoomed area and is repositioned, the zoom view is cancelled. This may be intended because any zoom is always cancelled when the cropping rectangle is moved, but if you want to make a precise crop, you cannot use a zoomed view. You then have to make several consecutive crops.
Re: Crop split window missing scrollbars
I see the problem of the missing scroll bars. Also both sides are incorrectly being zoomed to fit after every change of the cropping rectangle - just the right side should be zoomed automatically.
FYI, you can get the hand back by holding down the Alt key.
Good hint, thanks.
