Page 1 of 2
Histogram for part of an image ?
Posted: January 7th, 2015, 7:18 am
by Bernard
When a mask is active, the brightness curve will influence the image according to the white and black amounts, that's ok, but (I think) the histogram displayed is always relative to the complete image with 100% amount.
I would like to work on a specific part of an image, and I need the histogram of that part only, ignoring (ie amount 0%) the rest.
How can I achieve that ?
Bernard
Re: Histogram for part of an image ?
Posted: January 7th, 2015, 12:09 pm
There is no specific feature that does this, but you can make a copy of the image and use the mask with the Composite Transformation (and a solid overlay color) to make the masked area black and then ignore the spike in the histogram at zero.
Posted: January 7th, 2015, 1:06 pm
by Bernard
Thanks Jonathan, I will try that.
What I want to do is to work brightness and contrast separately for the foreground and the background.
Of course I can do that with a mask (and the inverted mask) looking visually at the result, but without the help of the histogram.
Would it be possible to have a 'masked histogram' that would ignore the part where the amount is 0% ?
Bernard
Posted: January 7th, 2015, 5:00 pm
I am looking at implementing this feature - it is a little tricky.
Posted: January 7th, 2015, 10:33 pm
It turns out I was able to add this feature to Brightness Curve, Color Curves, and Color Balance. I was not possible to add it to the histogram tool without a major rewrite. The new code should appear in the next regular update.
Posted: January 8th, 2015, 10:07 am
by Bernard
Jonathan,
That's absolutely fantastic !
Thank you so much for your support and such a quick answer !
I am waiting for the next update....
My best wishes for the new year to you and Kiril.
Bernard
Posted: January 8th, 2015, 12:33 pm
I just got the histogram tool to work also.
Posted: January 8th, 2015, 1:50 pm
by Bob Walker
Jonathan,
Thanks a lot for working this out. It's a very useful enhancement, and I look forward to using it.
Bob W
Posted: January 8th, 2015, 11:45 pm
by couman
Bob Walker wrote:Jonathan,
Bob W
Yes, indeed. Thank you
Posted: January 9th, 2015, 9:47 am
by Bernard
Thank you Jonathan !
Bernard
