Using PWP to enhance scans from negs
Re: Using PWP to enhance scans from negs
When you tried the workflow again did you run it against a different set of images? It is possible that there was a problem with one of the images rather than with the workflow itself. I can't really comment further without seeing the workflow. You can send it to me at support#@dl-c.com. Please allow some time for a repy since I am travelling and may not be able to respond right away.
tonygamble
Post by tonygamble »
It was the same set of images.
I deleted the rogue workflow to avoid confusing myself (!).
Thanks for your help. I'll send you another one if it fails. Hopefully it was a one off.
Tony
