Bug fix release 31-Aug-2019
Re: Bug fix release 31-Aug-2019
10) File | open multiple working OK. Open WS batch script with File | Open multiple as first command, then [Cancel] file open -> opens an empty image headed <DSC123.jpg> on workspace with error message 'bad input image' on the transforms. Note that the file <DSC123.jpg> is stored in the WS script at 'image index 1' although I saved the WS w/o images:
"image index 1 caption ″DSC123.JPG″ saved_as ″″ saved_on ″″ parent -1 bypass -1 same_size 0 size_specific "
and the File | close commands are not available.
So if user does not select a file, where should the WS script leave you? Probably at work space with batch | file open dialog?? or could cancel the batch??
For the next release PW now sets the caption to "File Open" if you cancel. It also now gives you the option of trying again, aborting and clearing the workspace, or continuing with File Open returning an error. The last option lets you double click on the File Open to select a file and then continue normally.
14) Open WS batch script, select files, click [run all] -> batch saves two copies of the file, so I have <DSC0345.jpg> AND <DSC0345 v1.jpg> in destination folder. Check file properties & both files have same time stamp!
The File Export in your script file is set to add a version number if the file already exists, so DSC0345.jpg is probably left over from an earlier run.
