Cropping multiple images
I have a number of images that I am wishing to crop to the same dimensions.
Although they start out as the exact same size, because they require leveling first, they change those dimensions, albeit slightly. Each image requires a bit different leveling, so each has a different outcome.
I tried cropping the first image to the required final size, constraining it to the 2 x 3 format, then using "Reload last settings" on subsequent images.
The first image I tried this on had different final dimensions (out by up to 35 pixels in one dimension). And of course, reload last settings becomes useless on subsequent images.
I assume, because the images were different sizes to start, reload last settings does not work for this circumstance.
So, how can I crop a large group of different sized images to the same format and dimensions (all images are larger than the resultant crop size) in an expedient manner? For the first image, I had to zoom in considerably to get the crop area to an exact dimension. I don't wish to do that multiple times, if I can avoid it.
Re: Cropping multiple images
The easiest way to do this is to use the Layout transformation. Once you set it up it takes care of everything.
1) bring up Layout and change the units to pixels, and then enter the desired image width and height.
2) click the + button to insert a new panel and drag its corners or sides to resize it to fill the entire output image. Check that the panel size is correct.
3) select Fit Panel - scale 1:1 as the scaling option.
Save these settings using the Settings menu under a name you can remember for future use or if you need to start over later.
To use it, select the image you want to crop as the Color/Image and then click the side by side button at the top of the dialog box to display the input image in the main image area. You can drag the cropping rectangle overlay as necessary to decide what part of the image you want to keep. Then click OK and Layout will crop the image to the desired size.
Repeat the previous step for the other images you want to crop.
I did find a problem with Layout cropping rectangle while testing this, but if you stick to the above procedure you should be OK.
layout v1.jpg (95.98 KiB) Viewed 1716 times
Two (three now) additional ideas (if I understood what's required) that perhaps could be useful:
1) Use 'Crop to Original Size' button in Level, which leaves the pixel dimension of the image intact, at the expense of introducing black solid color in the corners where there is no image anymore after rotating. If the Levelling is not too extreme and the crop substantial, those corners should fall outside of the cropped area.
2) Use the default Level cropping method, but sandwich Resize to original pixel dimension between Level and Crop.
3) And yet another possibility - It seems to be working in batch mode - the description is longer than what it actually takes; get rid of Level and Crop altogether and replace two of them with a single Warp. Set Warp to Rigid, and move and rotate the Warp rectangle to level and crop the first image (I don't know how to change cropping rectangle proportions to be different than the original image without actually warping it, though). Then, when you're happy with the size of your crop, set Scale Factor to 1:1, change Warp settings to Rotate Only and then click OK. Set Breakpoint on Warp and run the batch rotating the rectangle to level each image in turn - the cropping rectangle size and its centre should stay the same.
I normally do this with a short 3-step script:
1. Crop the image to the required ratio, for example 16:9 for tv-images
2. Resize to the required pixelsize, for example 1920x1080
3. Export the image to disk
If you define the Resize step as a Breakpoint you can adjust the cropping
CUDA not available
