I have posted a new release (2-Aug-2019).
Again fixed problems stopping PWP from running on systems before Windows 10 version 1703. Unfortunately, I do not have any computers running WIndows 7 or 8 here to test against, but this should work OK.
Bug fix release 2-Aug-2019
Re: Bug fix release 2-Aug-2019
I just tried the new version.
Still the same error message.
CUDA not available
CUDA not available
Are you sure it's exactly the same error message and that you are running the 2-Aug version? It looks like I forgot the update the version date on the 2-Aug version -- will fix this right now.
The error messages shows up as soon as I try to start the programm.
CUDA not available
CUDA not available
I found a computer here with Windows 8.1 and I will continue on this until I get a new version that works.
ok, no need to for a quick hack.
Good software need time.
I have a runnign program with version 2019-07-20
CUDA not available
CUDA not available
OK, this time I have gotten a version of 2-Aug-2019 that tests OK on Windows 8.1 and which presumably also works on Windows 7. I have replaced the 2-Aug version uploaded earlier with the update, so it will also list 2-Aug-2019 as the version.
This version seems to work now ok.
Thanks for this
Thanks for this
CUDA not available
CUDA not available
Hmmm, is it just me? I installed Aug-2 updated version, and "quick pick" is no longer functioning, space bar or letter key combinations. Is that something I could have turned off by mistake?
No, it was me. Fixed for next release.
