Crash with *.png-files
I created the adjusted *.png-file with PWP 8.0.560 (recent version).
The file opens fine and the transparent layer is shown as a mask.
The problem araises if I try to use the mask.
As soon I try to use the mask in the Mask transformation or with nay ohter transformation PWP crashes.
Any idea?
Snip v1.jpg (91.85 KiB) Viewed 28575 times
Re: Crash with *.png-files
Fixed for next release. It looks like no one every tried that before. If you need a fix quickly, I can post a replacement exe file.
Next release will be fine. No need to hurry.
Problem is solved with 5.0.561
Thanks a lot.
