Lazlo effect - den?
croos
Lazlo effect - den?
Post by croos »
More than 10 years ago we had some threads about accomplishing what was then called the Lazlo effect with PWP. Mostly used for sort of harsh looking portraits. Think old coal miner with wrinkles an black pores in need of a shave. The Lazlo effect accentuated that look.
I found some old photos, not at all portraits, where I had used that effect and wanted to play a little with it now, but of course I have forgotten how do to it. I guess the threads are gone and searching the new forum didn't turn anything useful up. But I think den made a writeup. Any chance that's still available somewhere?
Re: Lazlo effect - den?
https://www.dl-c.com/Discus-1/5234/3776.html
The original post this technique was based on is no longer available.
I encapsulated Den's technique and a copy of the original image in the attached script file. To run the script, just do a Script/Open Script command and select the script file. It will then ask you for the name of an image file to operate on -- once you pick a file it will open it and create the Lazlo effect on it.
Lazlo.zip
(132.03 KiB) Downloaded 1529 times
croos
Post by croos »
Thank you, Jonathan. I think that's the very thread I was looking for. Much appreciated.
The Lazlo Effect is really a variation based on the post imaging style of Dragan. An internet search for the Dragan Effect will produce links to many tutorials which have differing workflows that can provide ideas for your own style. For an example:
Creating the Dragan Effect -- https://support.corel.com/hc/en-us/arti ... ntShop-Pro
A basic PWP8 variation for the image example of the tutorial follows: HSL-SL Color/Tone adjustment of a HighPass/USM sharpened image version; and converting to SplitTone monochrome...
HSL-SL version.jpg (78.07 KiB) Viewed 52227 times
SplitTone version.jpg (78.17 KiB) Viewed 52227 times
The PWP8 script with a Copy starting dialog is attached.
Have fun exploring... ...this technique is not just for portraits but with variations works well for landscape and nature images as well.
DraganEffect - Old Man.zip
(1.31 KiB) Downloaded 1438 times
jsachs wrote: January 16th, 2021, 9:43 am https://www.dl-c.com/Discus-1/5234/3776.html
Hi Jonathan,
Could you describe the purpose of each step of the Lazlo workflow ? In particular, what is the purpose of mask1, mask 1a, mask 1b and composite's base mask ? Is one supposed to edit the masks for different source imageS ?
